Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - very lazy 400
Thread: very lazy 400
  #35 (permalink)
Old 02-21-2013, 10:42 PM
LJM97Z LJM97Z is offline
Originally Posted by 90caprice408 View Post
Yes I was on a tight budget and its my first build so I was ordering parts that looked good to me for the little bit of knowledge I had....it runs and drives fine it just doesn't have the umph I thought it would have from a standstill and off idle....but she comes alive around 3k...I don't really want to change much on this setup if I don't have to...this is also just a weekend car so gas mileage is no issue
I did something similar to my 406, installed a larger cam with alot of overlap & lost bottom end, even with 4.11s & a 4200 stall i wasn't impressed, had the timing at 37* all in around 2500 rpm, My compression is at 10.4 with 64cc "iron eagles", My piston volume is 8cc, You will be fine on pump gas with 11.1 on "aluminum heads", but your tune needs to be right, plus run a colder plug.
What i did'nt like about my cam was its 108 LSA, your better off with a larger LSA 112-114 with higher compression engines on "pump fuel", I went back to my milder cam & its loaded with torque, It even runs faster ET & MPH with the smaller cam, Its all on how much time you want to spend tuning it, plus your going to need more stall/gears with that cam.
My advice, change the cam, its not that hard,then install something that'll work with your 3000 stall & 3.73 gears, you'll be much-much happier, Heres the cam i'm running with a 2800 stall & 3.73 gears.
Lunati "barebones" line.
465/488, 224/234 @50, 112/107 2000-6000 RPM
Its runs great on 91 octane & 210-215 cranking pressure
It pulls around 16 inches manifold vacuum, sure its a bit mild, but i'm running 12.3s @ 109-110 with this cam.
