Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - very lazy 400
Thread: very lazy 400
  #44 (permalink)
Old 02-22-2013, 03:20 PM
90caprice408 90caprice408 is offline
Originally Posted by F-BIRD'88 View Post
I guess its a lot easier to post 3 or 4 pages of nonsense on teh internet than spend 10minutes to go to the garage and simply lock out the HEI's advance system so it cannot move, by binding it tight using two common plastic Zip ties,
and stick the rotor back on. Stick the weights and springs in your tool box.
reset the now fixed locked timing to 36deg BTDC and go for a ride.
It is just that simple.
Or .... you need a cam,, you need a dyno tune,,,, you need gears.... yad yada yada.
10 pages later
The first description u put up about locking out the timing did not seem that simple.....but if that all it takes that will definitely be the first step
