You do realise the locked timing is for testing purposes only?
What was propose by fbird is the same as jamming a stick under the front door to let fresh air in the house. Basically,take off cap and rotor play with advance weights to make sure they move Advance them with your finger by pushing the weights away from their resting position until they are fully open Jam a nylon pull tie in where ever you can fit it and attach 2(1 to each weight) This will "jam" the weights fully advanced. start car set timing to 35º drive car: test for ping when accellerating from stop test for part throttle drive ability carb especially idle will need to be set before driving Make sure you trim loose ends from nylon pull ties before installing cap and rotor While the cap is off: Take float bowls off carb and note front and rear jet sizes and power valve numbers. numbers are stamped onto both parts. alse note if rear of carb has a metering block or plate Do you have a holley? If its a carter/edelbrock,take out the metering rod and check number |
When I do it I remove the weights and springs. Then wrap the bare mechanism fully advanced with the two tie wraps.
Make sure the buckles of the wraps are pointed down under so the rotor goes back on. Make sure the rotor is seated correctly back on. Th weights and springs are not reused. You must reset the timing. 36deg BTDC. You will need the starter brace and the interupt switch for hot restarting. If you cannot do this get the local kid with a mini bike to show you. its permanent if you have done it right. |
http://www.hotrodders.com/forum/atta...=1361653644644
I have to leave ( the better half is ) someone explain where to put the ties!!!Read Cobalts post and click on the yellow high lighted area! For a test set you time at total with a light! mark the distributor base and block with a felt marker so they align now set base time so engine starts good and mark it again, After its tied off start it at the base time mark and turn the dist. to the total time mark and drive it (test it) you wont need a turn back for this test!!! I have to leave (The wife )LOL![]() Some one explain !!! If he doesn't understand " yes dear Im done )"LOLJester
You can accomplish basically the same thing by using very light springs that will allow the mechanical advance to go to full advance at a low rpm. Two light springs should be about right to have the mechanical all in early enough, but still have enough spring tension to return the mechanical advance to rest w/the engine off. This negates the need for a starter switch, while still giving all the available advance at low rpm.
A page w/some more info: Limiting/locking mechanical advance If you remove the weights and springs and use tie wraps, etc. to lock the liming, DO NOT remove the cam of the mechanical advance mechanism. It holds the advance plate to the center shaft. Last edited by cobalt327; 02-23-2013 at 08:39 PM. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
90caprice408 (02-25-2013) | ||
reloads?
I does not work. The light tension springs allows the timing to move around way too much at idle. The timing drops off when you go in gear and flairs up in neutral resulting in a idle that is all over the place and poor throttle response and a engine that loads up, stalls in gear and idles up and down all the time. With the locked out timing the cammed engine gets the stable timing it needs at idle . Gets a clean stable consistent idle and excellent throttle response. Yes the engine needs this much timing at idle. . Using the switch becomes second nature in a very short time. The benefits far out weight the bother. |
If you don't have enough sense to use enough tension, the timing might fluctuate. This actually takes a little thinking and maybe some small amount of trial and retrial to get set correctly, unlike your no-brainer "lock the timing, one size fits all" timing setting.
For accuracy, locked timing is worse than a stopped clock- a stopped clock is at least right twice a day...
A engine is not a clock. (with a cam like this in the motor and a auto trans),,,it ends up so close to dead on accurate that running any kind of a mechanical timing curve is pretty much a waste of time.
Works really well when combined with vacuum advance controlled by ported vacuum. (about 8 to 12deg at cruise and a limit of about 15deg max) Give an engine what it wants and it does something really surprising. It runs real well. This engine will run the best with the locked out timing. You may not like. But the engine will. |
At least, if the timing is going to be locked, go to the small amount of extra effort to secure the mechanism w/a screw or two. The quality of tie wraps vary greatly, some I wouldn't use to close a loaf of whole wheat.
I have been advising using ported when there's a need for a lot of initial timing for a long time, this is nothing new. Instead of bothering me, let the guy decide what he wants to do. |
| Lazy Lifter | Regal Beagle | Engine | 1 | 05-30-2008 12:18 AM |
| Lazy top end | BMM | Engine | 13 | 04-13-2008 10:03 PM |
| Lazy engine | n2oguy | Engine | 4 | 06-20-2006 04:17 PM |
| I'm lazy | BillBlue | Introduce Yourself | 1 | 06-11-2004 03:56 PM |
| UPS is lazy | 87442lover | Hotrodders' Lounge | 8 | 05-09-2004 08:05 PM |
