Very much MPH - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-06-2005, 06:16 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by bullheimer
saw them interviewing one of those 50's nascar racers who bootlegged whiskey back in the day saying his car would go "180mph up hill or down" and it was a pre 50's something or other but sounded like just about anything those guys drove would do it. on a back country road too. and no doubt at night. can you imagine that?
Sounds to me like he'd been "lightening" his cargo........
  #17 (permalink)
Old 05-06-2005, 09:15 AM
1300
HA-HA-HA-HA!!! :thumb up:
With lightened "cargo" we can go with 200+ MPH even on broken down car...but only in mind...only before hangover...
  #18 (permalink)
Old 05-06-2005, 10:17 AM
1300
Originally Posted by Max Keith
As for aerodynamics and streamlining, there are several things you can do to make those cars a little more slippery.
One is to lift the body off of the frame and remove the insulators. This will lower the body between 1-2 inches on the frame, putting it closer to the ground, reducing the amount of air flow going under it. Also lowering the vehicle on the suspension (not as in a lowrider) to get the correct ride height, and that is not a job for someone that isnt up to speed on setting up chassis. This will require resetting your front end geometry for the vehicle to handle properly.
Another trick is to use fine mesh screen on the grill, or even blank it out with sheetmetal. You will still get plenty of air flow under the bumper, to keep your engine cool.
Shaving off all the crome, door handles etc.
"Tightening up the Body", by realigning all the fenders, doors etc so you eliminate or reduce the gaps between them. Most needful of this is the gap between the hood and the fenders.
Close off openings in the bumpers, like slots for license plates.
Take sheetmetal and make end caps for the bumpers, to reduce the turbulance at the corners.
fill in the gap between the upper and lower back edges of the front bumper and upper and lower leading edges on the rear bumper and the body. One way of doing that on alot of vehicles is to shorten the bumper brackets so the bumper fits flush against the body work.
putting an air dam under the front of the vehicle works well. Place the air dam just below the radiator mount, and all the way across under radiator support.
Louvering the hood at the rear, just ahead of the firewall will allow all the hot engine compartment air to escape, reducing the resistance to air flow in the front end.
If you are good with metal work, raise the windshield out from its mounting tabs so it is flush with the roof and side posts.
Do the same with the rear glass, as well. With the kind of speeds you are wanting to go, you will want to install 2-3 retaining straps from top to bottom on the rear window, as that is a high vacuum area, and your window can actually be sucked out of the mountings.
A real spoiler on the rear deck will help in keeping the rear end down on the ground, as at high speeds, they do tend to want to lift. Beware though, spoilers also tend to create a lot of drag, like pulling a parachute, so you only want to put a couple degrees of down angle on it. Just enough to keep the rear stable at speed. best to use an adjustable spoiler. Use one that mounts close to the trunk, not one that sticks up a kazillion feet in the air.
Inclosing the underside of the car with sheetmetal will also make it slicker. Smokey Yunick did that successfully.
Richard Petty actually dented up the roof of one car like a golf ball, and that works as well. Would take an aeronautical engineer or a golf ball designer to explain all that stuff about laminar air flow.
Putting clear covers over the headlights, that mount flush with the body will reduce the parachute effect of the headlight wells.
Same with the tail lights if they are inset into the body.
Just a few things on making a brick slippery. They all work, and have been used for years.
Well, I read, read... In general and whole fine, thanks. But I'd like to update some details.
1) Lowering suspension.
Suspension with variable ground clearance, like that, which was optional on '59 Caddies and standard on Eldorados, still alive? It would be needed to keep ability to drive on back country roads.
2) Shaving off all the chrome, door handles etc.
Э-э-эÖ How doors will open? And can be kept chrome? I enjoy chromed trim on these cars...
3) I don't quite understand about lowering the hood at the rear.
4) Also not quiet understand about clear covers over the head- and taillights. I can't imagine, as it will look with bullet-style taillights.
5) Spoiler on finned cars? I don't mind about spoilers on mid '60 - early '70 cars, but on late '50Ö
  #19 (permalink)
dinger's Avatar
Studebakers were used quite a bit on the salt flats, they're fairly aerodynamic. Supercharged versions were available. Many of the 50's cars weren't actually all that heavy, they just looked heavy, depending on what you consider "heavy". This would make a cool project. Dan
  #20 (permalink)
Old 05-06-2005, 08:52 PM
Max Keith's Avatar
slippery cars
As for lowering the car on the suspension, this requires using shorter and stiffer coil springs in the front and lowering blocks between the leaf springs and rear axle, if your vehicle has leaf springs in the rear. If its got coil spring rear, then using stiffer shorter coil springs apply to the rear as well. This is not something that you will just walk in and find parts on a shelf. Using shorter coil springs with stiffer spring rates requires knowing your vehicles weight at each corner, and knowing the suspension geometry as well.
Linconln and Cadillac both had variable suspensions for a few years, but I believe the cost was too great for the demand and they stopped production of such units.
As for doing back roads, if you are going to lower a vehicle for aerodynamics and for handling, you will just have to take your chances on the chuck holes etc on gravel roads.
The chrome can be kept but the idea of removing it was to minimize the turbulance it causes, no matter how slight. when you shave off the door handles, this requires using electric celinoids to open the door latches or else leave your windows down all the time.
As for the hood, that was LOUVERING, not lowering, the hood at the rear.
Louvers are a small slot cut in the sheetmetal and are formed with an anvel that fits near the slot. What they look like is a very small hood scoop, about 1 inch tall and usually 2-3 inches wide. The opening would be facing to the rear, toward the windshield. Having several louvers across the rear of the hood, just ahead of the fire wall a few inches will allow the hot air buildup under the hood to escape, allowing more cool air to enter and cool the radiator. This will also, due to the air flow coming out from the louvers, reduce a hi pressure point at the base of the windshield, which is an air flow restriction. Again this gets into a topic called laminar air flow and I dont really understand it all, but do know it works.
Im not sure what you are referring to by bullit style headlights.
As for the golf ball effect, and the idea of using sand paper, which the texturing would have a similar effect, up until the late 70's, early 80's, most super speedway cars were running matte or flat finish paints just for that effect. I dont recall the exact year but it was probably when Winston took over the Nascar Grand National Class, that the idea of shiny paint jobs became somewhat mandatory. Gotta look pretty for the grandstands and the advertizing.
You will notice that when the NASCAR and other sanction teams go to Daytona prior to the opening of the season, to do test and tuning, vertually all of the cars are still in primer, which is a flat finish paint, and here again we get back to that laminar air flow thingy.
Spoilers on 50's and 60's cars.
The only reason they put those fins on cars in the first place was to give them a supersonic jet aircraft appearance, a theme which was followed through on both the windshield and rear gl**** of most of the hardtop vehicles of the time, As well as how instruments were clustered in the dash. The idea was to give the illusion of speed, as though one was flying his own Jet Fighter plane. If you look very carefully at pictures of the aircraft built during the 50's and 60's, then study the styling of most of the major auto manufacturers of the time, you will see a lot of styling cues were taken from aircraft, IE bullets in the grill to represent the intakes of jet turbine engines (49-55 Fords, particularly). Markers on top of the front fenders and hood ornaments that vaguely resemble gun sights, tail lights that look like the exhaust on a jet engine.
The one inherent thing putting fins on some cars did was give them some straight line stability at higher speeds, mearly by accident, Im quite sure.
These fins would have little effect on a spoiler, unless you are dealing with something like a 59-60 Chevy, which the fins did have a tendency to make a car light in the rear at high speeds, in which case, the fins would be fighting with the spoiler for air flow supremacy. A vehicle with fins that run straight up and down may help in creating a minor channeling effect of the air to assist directing it over the spoiler.
  #21 (permalink)
Old 05-06-2005, 10:29 PM
1300
[QUOTE=Max Keith]
[QUOTE]
Headlights? Oops, I meant Taillights, it was eclipse. I need time to read and understand, will be reply soon.
  #22 (permalink)
Old 05-06-2005, 11:47 PM
That article about the bootlegger that ran 180 all over, that was in Mopar Action, it was a large 4 door chrysler (supersized so it could hold a lot of the shine), stock looking with boring paint so Johnny Law wouldn't suspect that he was breaking any laws.
If you ever read about about any supercars, like a Speed 12, they say that about 240 is the highest a car can go, because of the drag factor just becomes so tremendous.
68
  #23 (permalink)
Old 05-07-2005, 07:40 AM
1300
68
Speeds about 200+ MPH should be enough to any Road Warrior, especially if itís a full-size car.
To: Max Keith
Actually, on Cadillacs this ďair suspensionĒ was not very expensive option, but very unreliability. Donít know about Lincolns, perhaps, too.
And that: so, what with gearing and tranny mods in all?
  #24 (permalink)
Old 05-07-2005, 10:26 AM
1300
Idea
Hey,comrades,these aerodynamic improvements can not be those visual improvements, for which one I so long search?
In sense, they can give to these cars more awesome appearance?
  #25 (permalink)
Old 05-07-2005, 08:44 PM
Max Keith's Avatar
variable suspension
About 10 yrs ago, Lincolns were offered with a variable ride height, which was determined by some computer setup, when the car reached somewhere around 60-70 MPH, the car would lower itself on the suspension, mechanically, about 2 inches. I was under the impression Cadillac had a similar system. I remember the Air Ride system used in mid 50's Olds, Cadillacs, and Buicks, and they had a problem with the air bladders blowing out at the wrong time(if there ever was a right time). A cousin of mine had a 58 Olds wagon, I think it was, had the air ride in it, and was hooked to a compressor on the engine. He finally got tired of replacing the air bladders and went with a total spring setup and did away with the compressor and everything. Worked great when it worked, though.
As for 200 MPH bootlegger cars, most of them during the 60's and early 70's (the waining years of the real bootleggers), most did run big block Plymouths or Doges or Big Block Fords, in full sized sedans. Take into consideration that these were generally supercharged etc, and were capable of pulling these 4000 LB cars at well over 200 MPH.
Even the old sedans that ran Flatheads were capable of running well over 130-140 MPH, even with 40 Gallons of Moonshine in the trunk.
To see what can be achieved with stock bodied autos, one only has to look at the records set at Bonneville.
  #26 (permalink)
Old 05-08-2005, 02:06 AM
1300
Гы. I knew, that those cars have great potential, but at all did not imagine, as far as. I thought itís very difficult to accelerate them up to such speed. Yes, itís true mighty cars. Seems, best of late Ď6o Ė early í70 musclecars (like hemi-powered MOPARS) can run around 200 even more easy.
Large displacement rules!
  #27 (permalink)
Old 05-08-2005, 05:48 AM
willowbilly3's Avatar
Last journal entry: Body mods
Originally Posted by BillyShope
Wasn't it Andy Granatelli who "streamlined" a '57 Plymouth and ran it at Bonneville? Should be able to find it somewhere on the 'net. Come to think of it, I think it was on the cover of one of the Hot Rod annuals.
Actually I think it was Brock Yates and the n"Suddenly" car. Ugly as sin with all the extra tin over the headlights.
I think a better platform would be a Studebaker. I fail to see any sense in trying to make a flying brick, just because it hasn't been done. Makes about as much sense as putting a Merlin in a Winnebago.
  #28 (permalink)
Old 05-08-2005, 06:35 AM
1300
Nevermind. That's OK
Last edited by Nightrider; 05-08-2005 at 04:05 PM. Reason: wrong understanding of previous reply
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
140 mph over the speed limit! dinger Hotrodders' Lounge 38 08-07-2005 05:23 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Update on 205 mph speeding ticket dinger Hotrodders' Lounge 14 09-27-2004 12:23 PM
200 MPH road warrior BillyJoe General Rodding Tech 16 01-07-2004 10:52 PM
