Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Very shallow Oil Pressure & Battery Voltage Gauges?
Old 08-24-2012, 01:57 PM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
I'm in the middle of designing a custom instrument panel and looks like I have room for Oil Pressure & battery Volts gauges below the water & gas. (See picture). The panel fits in front of an '95 OEM instrument panel.
Trying to make it look similar to the '37.
These will have to be 2 inch diameter gauges.
The gauges will have to be very shallow to fit in front of the OEM instrument cluster and fit behind the custom panel.
1) Connections for the gauges would have to be on the side and not on the back. Are there gauges with this type of connections?
2) What are shallowest after market Oil Pressure & Voltage gauges you have seen?
Thanks
Mutt
Name:	Dash Assy, in 37 Dash, v0.04 Details on new flat panel.JPG
ID:	67599   Click image for larger version
