Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Very shallow Oil Pressure & Battery Voltage Gauges?
Old 09-17-2012, 08:48 AM
Mutt's37Buick's Avatar
Mutt's37Buick Mutt's37Buick is offline
Thanks for the feedback.
I'm trying to use the instrument panel out of a '95 Buick Roadmaster primarily for the speedometer and the system warning lights. My plan is to hide the dummy lights behind hinged access panels. This instrument panel connects directly to my wire harness. May be able to insert pressure & battery gauges in the cluster, but it will be tight. Another option I'm exploring is attaching a 1.5" extension shaft on the speedo gauge to move that needle out 1.5". Then I could mount 4 support gauges in front of the '95 panel. This would provide more flexibility on placement of the support gauges. Attached is a picture of the '95 cluster and the '37 cluster.
See pictures.
1) has anyone else added an extension shaft to a gauge in this way?
2) would an extension shaft add to much mass and cause the speedo to not operate?
Thanks
Name:	IMG_0086 compressed.jpg
ID:	67927   Click image for larger version
Name:	comp ins cluster.jpg
