Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Very Simple Power Rack and Pinion Steering Question
Old 01-25-2008, 12:43 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Buy a manual rack..you will mess up the power rack running it without fluid.
It would probably work for a while, but IIRC it is a different ratio as well so steering will be harder, and you will tear stuff up.
Later, mikey
BE different....ACT normal.
