VETTE REAR END TORQUE SPECS - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2002, 05:16 AM
apprentice geezer
Post VETTE REAR END TORQUE SPECS
AM DOING REAR OF 73 VETTE. NEED TORQUE SPECS FOR DIFF CARRIER CAPS (I CANT FIND THESE SPECS ANYWHERE.)
ALSO NEED USED PINION REASSEMBLY TORQUE SPECS (@ YOLK) (I KNOW I HAVE SEEN THESE SOMEWHERE, BUT SINCE I NEED THEM I CAN'T FIND)
THANX FOR ANY AVAILIBLE HELP! BEST HOLIDAY WISHES TO ALL MY HOTROD BROS !!
Old 12-23-2002, 02:32 PM
Post
The only thing I have on 67 to 73 Vettes is from Motors Repair Manual " 5. Install axle shaft in reverse order of removal, being certain to rotate yokes so that trunion seats are phased 90 degrees apart. Torque drive flange bolts to 70-90 ft lbs and U-bolt nuts to 14-18 lbs."
Hope this helps
Trees
