vibrates when someone else rides with me??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2010, 12:24 PM
This is going to sound strange but my truck vibrates a small amount with someone else is with me and doesnt do it at all when im by myself. I checked both U joints and then pulled the diff cover and checked for correct backlash. the pinion seems to be tight and the rear doesnt make any odd sounds im starting to run out of ideas anyone ever had a situation like this?
Old 08-02-2010, 01:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're serious, it could be worn or missing body mounts, worn suspension bushings, a pinion angle right on the ragged edge of specs, that when loaded puts it over the edge.
What vehicle, mods, etc? Where is the vibe felt? Under power, coasting, in neutral, in gear, etc.
Old 08-02-2010, 03:02 PM
If I was younger I might remark about the gross tonnage of your passenger...try picking up bikini models instead....but Im older/wiser and engaged...so I wont
Old 08-02-2010, 06:23 PM
Overdriv's Avatar
Always drive alone. Problem solved.
Best Rides yet! Lee468 Hotrodders' Lounge 3 07-21-2004 09:13 AM
Bringing all Rides together 78SilverShark Hotrodders' Lounge 25 04-14-2004 08:12 PM
Damn You Rides Magnus_Jager Hotrodders' Lounge 18 03-14-2004 08:28 AM
Rides R-U-L-E-D this week!!!! frackster66 Hotrodders' Lounge 26 01-14-2004 05:32 PM
my rides purpleskunk Hotrodders' Lounge 14 11-18-2003 12:21 PM
