Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vibrating ford POS
Old 12-14-2004, 09:51 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
I found it!! Lost most of # 8 intake lobe. The valve is opening, but not nearly enough. After seeing some of the posts, I decided to re-do the compression test, as I had someone else do it for me 'cause I was busy on another vehical. Turns out #8 was low, and wet test didn't bring it up. Pulled the cover off, intake on 8 moved about half as much as the rest. Looks like cam swap time!! Thaks for all the quick replys, guys.
