vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2006, 06:58 PM
vibration
I have a 1970 Chevy Nova, 350 CU IN 4 speed. The car starts to vibrate when you hit about 60 MPH. Nothing real bad but enough to bug you. It does not go away or get worse by going faster. I have put on brand new tires, and a new drive shaft. These two items did help but did not eliminate the problem. also if I am going over 60 and push in the clutch it does not cut down on the vibration so I don't think it is in the engine. Any Thoughts??
Thank you
Rick
Old 11-25-2006, 10:54 PM
Your driveshaft angles are wrong. You need to check the driveshaft and pinion angles to be sure they are complimentary.
Try: http://www.2quicknovas.com/happypinions.html
Lots of good info and advice.
Mystery Vibration: long post Dano1972 Engine 6 06-20-2005 02:51 AM
Vibration at speed Doc68 Transmission - Rearend 141 01-22-2005 07:53 PM
Vehicle Vibration Smittyd55 Transmission - Rearend 3 03-01-2004 05:31 AM
drivetrain vibration catscan4free Transmission - Rearend 8 12-27-2003 03:43 PM
Troubleshooting Driveline Vibration PrimaDude Transmission - Rearend 9 07-01-2003 10:57 AM
