Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vibration
Thread: Vibration
Old 10-13-2012, 07:21 PM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Pinion angle changes cause that. Nose of the rearend drops enough to cause the u-joint to bind a bit. Goes away when you hit the gas cause pinion rises enough to stop the vibration.
What's your pinion angle now?
Try moving it up a couple degrees!
The Following User Says Thank You to RWENUTS For This Useful Post:
Rocketbird (10-14-2012)
