Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vibration
Thread: Vibration
Old 10-13-2012, 06:33 PM
John long John long is offline
Originally Posted by RWENUTS View Post
Pinion angle changes cause that. Nose of the rearend drops enough to cause the u-joint to bind a bit. Goes away when you hit the gas cause pinion rises enough to stop the vibration.
What's your pinion angle now?
Try moving it up a couple degrees!
Agreed. definitely check pinion angle while you are under it..... John L
