Vibration in 1984 Ford Country Squire Wagon - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2010, 12:31 AM
Around 60 mph and up I get a strong vibration that seems to get heavier and then softer as I drive. It dosen't effect driving just isn't smooth. Front tires and wheels have been balanced and the suspension seems tight upon inspection. Any ideas?
Old 12-25-2010, 09:10 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could be a u-joint check them.
Cole
Old 12-25-2010, 10:20 AM
T-bucket23's Avatar
Wiki Edits: 26
Do you feel it in the floor or in the wheel. Rear tires out of balance will cause a vibration that comes and goes. Also as mentioned U-Joints can also cause a vibration. A U-Joint vibration usually will not come and go, it usually gets worse with speed.
With U-Joints, you can look where the cup meets the cross and look for signs of rust.
Chet
Old 12-27-2010, 09:48 AM
Thanks for info, didn't have access to computer till now
Old 12-27-2010, 09:57 AM
eloc431962's Avatar
Wiki Edits: 37
Are you saying that when it's heavier when you drive then gets softer.
Ok so are you saying that when it's actually reaching it's worse spot with the vibration then say you level out and are possibly easing off the gas then it gets softer with the vibration then ?
If so then it can very well be a u-joint and still yet a tire / wheel problem. JMO
Cole
Old 01-13-2011, 08:33 PM
awert's Avatar
58/58
many years ago i had a strange vibration problem , no one could find it, until Mr. smarty came along, ended up being the drive shaft...some how it got a little skewed... I'll never forget that, took over a month to find the problem....
1987 R-10 ...1984 Caprice Classic wagon BruceT Introduce Yourself 1 06-21-2007 10:56 AM
1987 R-10 ...1984 Caprice Classic wagon BruceT Introduce Yourself 1 06-19-2007 10:04 AM
1964 Ford Galaxie country sedan wagon raymrajak Suspension - Brakes - Steering 6 04-20-2006 06:17 AM
59 country sedan wagon sheetmetal hotrodtodd@canada Body - Exterior 9 02-03-2004 12:01 AM
Suggestions on Country Squire Woodgrain? Django Body - Exterior 3 11-07-2002 02:43 PM
