Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vibration
Thread: vibration
Old 12-24-2003, 06:14 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
are you sure no rims are bent? any tires out of round? did you mark the driveshaft the first time you removed it to be sure it`s orientation was correct upon reinstallation? the balancer is a 350 balancer and not a 400? how about the flywheel? have you checked the transmission mount and motor mounts to assure all are tight and none are broken? in some cases I`ve seen a flexplate cause vibration problems and none appeared warped to the naked eye. have you checked the front wheel bearings? I`d go over all these things with a fine tooth comb.
