vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2012, 08:21 PM
vibration
i have a 49 chevy pickup with a 69 nova rear and front end. i have vibration in the seats and etc. it is more noticable at around 40 mph and above. it is not a bad vibration but iratating. i have had a new drive shaft made at a machine shop and still have the same problem. can it be in my rear end. also what gears will be best in the rear end for street and highway 308 or 342.
Old 05-20-2012, 09:44 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
1. Have you had the tires balanced?
2. You say you had a "machine shop" make a new drive shaft. Was this shop setup to balance a drive shaft?
3. Could be a bad belt in a tire.
Old 05-21-2012, 05:46 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I would also add, check your pinion angle.
Old 05-21-2012, 08:18 AM
delawarebill's Avatar
vibration
i'm wondering if u have the 2 pc wheels with the floating spacers inside ????? if u do pull the wheels, turn inside up and put in all your lugs. drill two 1/8" holes (not all the way) and put in split pins to hold them.. now get them balanced... those floating centers drove me nuts and this was my fix...
Need help with vibration in S-10 57Handyman General Rodding Tech 10 04-11-2010 01:57 PM
vibration????? 350olds Engine 1 03-06-2007 10:55 PM
vibration koolkash Engine 3 01-26-2005 09:03 PM
vibration dankarol Engine 4 12-25-2003 12:15 AM
Vibration markiemyster Engine 4 07-11-2003 10:05 PM
