You can measure the cap diameter and cross size (width) and check NEAPCO for listing by dimension.You need to check both sets of caps, keeping in mind the cross size may be different for the other set, so be sure to keep track of which part of the joint the caps came off of.
In other words you can come up with a part number by maesuring the joint and picking the one from the catalogs dimensional section, to arrive at a part number, which you can purchase or crossreference for a different brand. I used the crossreference manual here a while back. Put a 8.8 explorer rear in a 5.9 dakota. Used the dodge drive shaft. Used the hybrid joint and the driveshaft fit perfectly. Didnt even need to cut the driveshaft.
Fact is stranger than Fiction |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
Rocketbird (10-14-2012) | ||
I have a friend with a T bucket; His driveshaft is short...very short and he changes his U-Joints either every 2 or 3 years; just to be safe. His driveshaft angles are pretty bad. It doesnt exhibit any weird behavior though. Well, he had GM Metric front disc brakes on the front and it had a horrendous wobble at 70mph (IIRC). Change to a smaller caliper and the wobble went away.
| Vibration | farmerea | Transmission - Rearend | 1 | 08-24-2012 02:52 PM |
| vibration | Sobi85 | Transmission - Rearend | 3 | 09-18-2006 04:26 AM |
| Vibration | RCastle | Suspension - Brakes - Steering | 7 | 10-25-2004 04:26 AM |
| vibration | dankarol | Engine | 4 | 12-24-2003 11:15 PM |
| vibration | markiemyster | Transmission - Rearend | 4 | 11-30-2003 11:13 PM |
