Internal problem. Harmonic balancer. Transmission. Torque Converter. Tailshaft bushing. Driveshaft. Wheel bearings. Tire balance. Ujoints. Etc.
First determine if its RPM based, or speed based. Does the vibration occur if you rev the engine in park or neutral? If you are driving down the road, and put the engine in neutral, does the vibration go away? What RPM and or speed does the vibration become noticeable?
Bringing history and technology together. |
vibration
it seems to be at low RPM and even more noticeable when the engine is cold...It it worst when starting but at higher speeds and when the engine is warm it begins to get less noticeable. I have taken it in and the mechanics claim is not the CV joint or wheel bearings which i thought it might have been
Try and answer all the questions I listed. Knowing if its in park and neutral or just in drive and reverse will help a lot.
