Vibration 8.5 10 bolt. need some help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2006, 04:17 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Hey guys, I have a problem once again. I started hearing and feeling a vibration when accelerating coming from the back of my car. A couple of years ago I put posi and changed the gears in the rear end. (8.5 10 bolt) Not knowing well enough at the time I reused the crush sleeve. Could this be causing the vibration? now that I understand things a little better. is the crush sleeve supposed to put pressure on the bearing so it will not slip? I just took the rear end all apart its looks like it might have been spinning but looks to be no major wear.
Thanks.
Old 08-27-2006, 09:01 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
The crush sleeve does just that it crushed to a certain point & holds the gears on the right spot .
Im sorry but it could be a dozen different things but that seems the best place to start.
"SlowRide66"
"Illegitimis non carborundum"
Old 08-27-2006, 09:11 PM
Red_Rider52,
The crush sleeve is used to keep pressure (pre-load) on the back side of the pinion bearings at a given torque of the pinion lock-nut. Once it has been used it needs to be tossed.
I would check the "U" joint bearings.
Does the vibration come in at a given road speed and then go away at a little higher speed?
Scholman
Old 08-27-2006, 09:24 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Rear end gears usually don't vibrate unless there REALLY bad. A U joint like was previously stated, or a pinion bearing or carrier bearing even an axle bearing could cause a vibration. If it has a bad carrier or pinion bearing you really need to replace all the bearings due to metal contaminating the gear lube and getting into the other bearings. If you just replace the bad bearing its a risk that another will fail soon after.
Old 08-28-2006, 05:57 PM
Thanks for the replies. I have done some work on the car and have not found the problem yet. I took the whole rear end apart and everything looked to be ok and installed a new crush sleeve. I have just replaced the U joints and it is still there. The vibration only happens around half to 3/4 throttle in first and second gear. Could it be coming from the transmission its a TH350. Thanks.
Old 08-28-2006, 06:42 PM
red_rider52,
This sounds like an alignment problem.
Have you raised or lowered the car?
Also check the transmission mount to see if it is allowing the tailshaft to raise up when you give it the gas.
Good Hunting
Scholman
Old 08-28-2006, 06:46 PM
scholman... you might be on to something I had the engine and transmission out about a month ago I did not notice the noise/vibration the first week or so. if its not aligned properly how would i go about lining it up.
Old 08-28-2006, 07:59 PM
Rob Keller's Avatar
Wiki Edits: 38
What did you have the motor & trans out for?
"SlowRide66"
Old 08-28-2006, 08:13 PM
The motor was out because of a cracked block.
Old 08-28-2006, 08:45 PM
Rob Keller's Avatar
Wiki Edits: 38
OUCH !
what kind of car are we working on?
"SlowRide66"
Old 08-29-2006, 01:45 PM
It is a 1967 Firebird with a sbc 383 and Th350 transmission
10 Bolt 8.2 / 8.5 TORI1 Transmission - Rearend 3 06-01-2009 08:10 PM
8.5 chevy 10 bolt question 75sprintguy Transmission - Rearend 3 05-14-2006 05:06 PM
8.5 chevy 10 bolt Dragster13 Transmission - Rearend 6 12-03-2005 03:07 PM
8.5 10 Bolt Chevy Info Needed jsteve068 Transmission - Rearend 6 09-26-2005 04:09 PM
12 bolt with 10 bolt carrier? JamesRS Transmission - Rearend 3 01-17-2005 08:59 PM
