-   -   vibration (http://www.hotrodders.com/forum/vibration-98359.html)
Sobi85 09-17-2006 06:35 PM
vibration
I have a 2000 Chevrolet S10 2.2 When i reach about 35mph, there is a vibration. it goes away if i let off the gas, but comes back when i accelerate in the slightest bit. no shaking with the brakes. only at a certain speed while accelerating. please help
Chazmac 09-17-2006 07:31 PM
Check for a tight U-joint or bad pinion bearing. Sounds like u-joint...
Sobi85 09-17-2006 11:14 PM
Thanks a lot Chazmac!
herc88 09-18-2006 04:26 AM
I am not sure about the small trucks have them but a carrier bearing can cause similar symptoms. If equipped check the bearing and rubber around it for damage.
