vibration problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2005, 08:38 PM
vibration problem?
I had my ford 8 inch rebuilt by a friend who says hes a mechanic..... anyway he replaced the 3.00 with 3.80 and put a lock-right locker in it. since having it back in the car I have noticed a fairly bad vibration once I get above 70 and is real bad when keeping speed there, meaning not decel or accel. I can kind of notice it around lower speeds barely. it feels like a not so smooth road at lower speeds. and again I can only feel it when maintaining speed and it dissappears on accel or decel. there are a few things I think it might be and want someone to agree with one hopefully. also the rear end doesnt howl or make any noise and there isnt any big clunk going into gear so I dont think it is to loose, also it is dependant on the speed not rpm of the engine. while having the axles out I had them standing on end on the lug bolts and one fell over once. could that have been enough to bend it and creat a vibration? also I really tightened my U-joints down good - its in a 70 ford so it has the old style u bolts. could I have tightened them to much? I am scared to death its my rear diff. please tell me it IS one of the other things or that the diff wouldnt cause that sort of vibration without noise. thanks
Old 05-10-2005, 08:57 PM
poncho62's Avatar
Wiki Edits: 5
Sounds more like a "U" joint to me.
I wonder if he put the "U" joint back in the same position as it was before. Sometimes, it makes a difference.
Old 05-11-2005, 11:51 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I agree with poncho it sounds like the U-Joints on the drive shaft. Do you know if the drive shaft was installed in the same position as it was removed. IMO it's a good idea to mark the U-joint cap and the rear yolk so you know that it is going back together the same. You can try this remove the drive shaft from the rear end and rotate it 1/2 turn and retry with a road test.
No IMO I don't think knocking over the axle shaft would cause it to bend.
let us know what the fix is, good luck
Old 05-11-2005, 12:36 PM
I wasn't that carefull about putting the shaft back in the same position, in the past I never paid attention to that and always been ok, I suppose I could have always been lucky on getting it back on the same way. but I am going to take it off tonight and replace the whole u-joint anyway. and I will repost on if it fixed it.
Old 05-11-2005, 08:08 PM
I changed the U-joints and test drove it. it seems a little smoother but still has a pretty good vibration that I can feel at high speeds only when I barely give it gas so that there is no load on the rear. could this possibly be a common sort of thing with lowergears? another thought I had and this is a long shot, but since I now have a locker in the rear end and my right tire which is the one that used to only spin has alot less tread on it. could the difference in tread heigth be enough to make the locker want to dissengage because of the difference in revolutions caused by different diameters at high speed. or would that difference not be enough to make a difference.
Ignition Problem malibuman66 Electrical 17 01-24-2006 01:05 AM
Have an odd vibration...need some help 357ford Transmission - Rearend 8 11-14-2004 08:09 AM
Overheating problem slik Engine 7 09-16-2004 06:59 PM
Vibration Problem missconduct Transmission - Rearend 2 07-20-2004 10:12 AM
Oh-ooh vibration woody51 Transmission - Rearend 1 09-18-2003 07:06 AM
