Is it more noticable at certain speeds or rpm? Does it vibrate at 4500 in all gears? Or is only in high gear at highway speed? Does it vibrate in neutral at that speed or do you have to throttle it up to get it to vibrate?
Let us know John |
I agree with Johnsongrass. The lower gears have sped up your driveline, ( thats why you didnt notice it before) See if you can find a good driveline shop and get them to balance it.(replace the ujoints when you have it out) I have a friend here that has a balance machine and it is interesting process to straighten and balance a shaft.
Also check the slip yoke and bushing in the trans. Keep us informed. Nothing more frustrating than never hearing if we helped or not. John Last edited by propaniac; 12-30-2005 at 10:11 AM. |
Im thinking "U" joints also.......they can still be tight, but dried out which will cause vibration. Replace them both....they are cheap enough, and a simple fix.
Ontario Rodders |
I tried putting it in neutral today while on the highway and the vibration was still there. Both U-Joints have been replaced. I believe you'll may be on to something with the drive shaft since it still vibrates in neutral and as propaniac stated the speed of the driveline has increased compared with before. As soon as I get the chance I will pull the drive shaft and find someone to check for straightness and balance. I'll let you'll know what I find out. Thanks again for all the suggestions.
Turning the "U" ,joint 180 degrees in the rear yoke may also make a difference.
Ontario Rodders |
Steve
Just a thought, nobody has said motor or transmission mounts. I replaced all of mine and it made a huge difference. I would imagine it could be the rubber mounts just given the age of the vehicle unless the have been replaced.
Check the diff yoke, I had one side worn on a 9 inch and it chopped out 2 rear unis in 2 weeks. Also consider driveshaft diameter, check the shaft from a factory 4.11 geared truck - they may differ. Is your pinion bearing preload ok? It all points to a problem between the g/box planetary set and the pinion as this part of the powertrain is the one that has seen the increase in rpm.
| Ignition Problem | malibuman66 | Electrical | 17 | 01-24-2006 01:05 AM |
| Driveline Vibration-Cause-Engine Problem, HELP | 71gtx | Engine | 12 | 01-19-2006 09:00 PM |
| Found low oil pressure problem.... | kc_ksom | Engine | 2 | 09-06-2005 07:01 PM |
| Vibration Problem | missconduct | Transmission - Rearend | 2 | 07-20-2004 10:12 AM |
| Vehicle Vibration | Smittyd55 | Transmission - Rearend | 3 | 03-01-2004 05:31 AM |
