vibration problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2006, 06:17 AM
turbo 350
my truck vibrates lightly while driving and I have had to replace my hanger bearing but that didn't fix the problem. when I put it in nuetral the vibration goes away, any suggestions?
Old 02-13-2006, 06:25 AM
poncho62's Avatar
Wiki Edits: 5
Have you checked the "U" joints?....................They may be seized....still seem tight, but too tight. I have seen that cause vibration.
Old 02-13-2006, 06:46 AM
yes i have checked the u-joints, they are old but they do not have any play in them and they do not seem to be stiff or froze up.
Old 02-13-2006, 08:45 AM
vibration problems
my 1975 chevy truck ( 350 sb) , auto (turbo 350) has a light vibration that comes and goes. I have replaced the hanger bearing, and checked the u-joints which seem to be good ( no free play and they do not feel like they are froze up or stiff) but i can't figure out this vibration. the vibration goes away when i shift it into nuetral. someone please help before i go insane!!!
Old 02-13-2006, 09:11 AM
40bowtie's Avatar
It could be a few things. The first thing that comes to mind is do the U-joints have a grease fitting ? If not they may be dry. Seen that many times. They still feel tight, but you get a small vibe. Pull the back one off at the rear end since it's the easy one and see if any bind is there. I bet it's dry.
Old 02-13-2006, 06:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I merged the 2 threads with the same question started by mwdbham.
thanks for your attention
Old 02-13-2006, 09:49 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Perhaps it's torque converter shudder?
Mystery Vibration: long post Dano1972 Engine 6 06-20-2005 02:51 AM
Vibration at speed Doc68 Transmission - Rearend 141 01-22-2005 07:53 PM
Vehicle Vibration Smittyd55 Transmission - Rearend 3 03-01-2004 05:31 AM
drivetrain vibration catscan4free Transmission - Rearend 8 12-27-2003 03:43 PM
Troubleshooting Driveline Vibration PrimaDude Transmission - Rearend 9 07-01-2003 10:57 AM
