Vibration under 2000 RPM's - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 10:02 AM
dsgb610's Avatar
I be Strokin!!!
What would be the cause of a slight vibration/shake while under 2500 RPM's it shakes the WHOLE TRUCK. My first thought was the Exhaust but everything seems good to go. What would I get if the harmonic balance and flywheel were out of sync? They are both from a 383 kit and internally balanced but my machine guy recommended that they ext balance them anyway.
Old 04-22-2012, 12:23 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
By vibration, you mean at a stand still or while driving? And by 383 kit you mean the damper and flexplate (neutral balance...) came as part of a legitimate rotating assembly? And the rotating assembly was balanced, yes? Is is an aftermarket crank or a cut 400 crank? What kit is it?
Semper Fi
Old 04-22-2012, 12:40 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 we need more info please.
Cole
Old 04-22-2012, 01:08 PM
dsgb610's Avatar
I be Strokin!!!
Actually it only occurs while in drive when no gas is being given to the engine. Once I apply gas it smooths out the flex plate and Harmonic were both included in my 383 kit. My machine shop insisted on re balancing them even though they both were supposedly internally ( pre) balanced. He did not report any errors. I have a eagle 400 crank that was included it the kit I purchased from eBay.
Old 08-05-2013, 08:28 PM
dsgb610's Avatar
I be Strokin!!!
*UPDATE* Turned out it was a defected harmonic balancer
Old 08-05-2013, 09:36 PM
sedanbob's Avatar
Thanks for posting the solution!
2000+ RPM stumble sooper Engine 10 03-04-2010 08:40 AM
Vibration at 2000 RPM in SBC. "HELP" 53 Studebaker Engine 19 10-06-2007 08:14 AM
Rattle at 2000 rpm's on accel only gsegan@wowway.com Engine 7 06-29-2007 03:27 PM
Engine vibration at around 2000 rpm fumplet Engine 1 02-20-2006 01:19 PM
4.3L will not run above 2000 RPM 2000blazer5speed Engine 6 06-11-2004 05:54 AM
