Vibrations - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 02:00 PM
Vibrations
I have a 1969 Chevelle with a 1980 TH400 and i was wondering if it could be the source of my vibration? At speeds over 30mph. when i let off the throttle the car has a very noticeable vibration but once back on the throttle the vibration is gone. Can this be the transmission and how can it be solved? And also when shifting in to drive or reverse the brake has to be applied hard so the car wont take off at idle. How can this be solved.
Thanks for the help. Mike
Old 05-16-2006, 02:15 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Vibration problem may be the torque converter bolts loose? What is you idle set at?
Steve
uneven cross u-joints. uncurable harmonic vibrations? bullheimer Transmission - Rearend 7 06-16-2005 11:14 AM
Clanking and vibrations Slant3 Transmission - Rearend 4 09-05-2004 12:12 AM
Vibrations Sonkey Transmission - Rearend 1 03-20-2004 05:02 PM
Bad vibrations propaniac Transmission - Rearend 18 09-13-2003 05:03 PM
low rpm engine vibrations...why? Gearhead forever Engine 1 04-26-2003 09:06 PM
