Vic Jr...for SBC..tall or short?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2002, 11:15 PM
Post Vic Jr...for SBC..tall or short??
Edlelbrock makes a short and tall vic jr. Does one preform better than the other or does one's application beat the other, a carb spacer is the choice of many preformance seeking people. Does the taller one incooperate this spacer in its height?? THANKS ALL! Dave
Old 10-14-2002, 11:20 PM
E.T. divided by $ spent= Speed
Post
I would think that the tall one would have a higher rpm range.
Old 10-15-2002, 04:06 AM
Post
the lower plenum makes power at a earlier rpm. max is around 6500 ish.
i would get the lower and use a spacer if desired.
[ October 15, 2002: Message edited by: Necro ]</p>
Old 10-15-2002, 06:47 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
The taller design is to increase plenium volume which, yes is the same as adding a carb spacer. It will generally take some torque away from the low end, and add it at the upper end of the power range. Unless you are going to be drag racing and spinning the motor to 8000rpm, I would get the low volume type.
chris
