VIN # on a 1932 chevy 5 window coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2009, 01:37 AM
I have a 1932 cev 5 window coupe that i want to regester to my name, but I can't find the VIN # can anyone help me out
Old 12-13-2009, 11:34 PM
327NUT's Avatar
I will say "most" of the older cars didn't have VIN#'s.....but they did have serial numbers stamped into the frame. You might try looking on the top portion of the frame in front of the cowl.
Old 12-14-2009, 07:02 AM
Wiki Edits: 31
should have a 7 digit Engine number.. it would have been stamped on the original engine and stamped on the frame or Cowl somewhere
Old 12-14-2009, 07:31 PM
the car has no engine,I took the # off the fire wall to the ministery they said it was no good that is where I am stuck
Old 12-20-2009, 07:48 PM
tnovot's Avatar
Try looking on the interior vertical section of the floor board - I'm refering to the backside of the firewall. That's where the VIN is on my 1936 GMC.
Terry
Old 09-12-2010, 07:00 PM
Young Stovebolter
Last journal entry: First body mock up
If you don't have it registered yet
I have two 32's both had the serial number under the floormat on the passenger side I have heard of it being found on the drivers side also. It is not stamped anywhere else. I have went over the frames with infrared and it is not there. The number on the engine is different but in many states they will use it to title the vehicle. I don't know what the laws are up there. The problem is that the plate is usually gone because the wood doesn't hold up. If it is there you will probably need infrared to read it. You can order replacements from
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old 09-13-2010, 05:29 AM
OK I will check that out I am in South Korea right now for work but when I return I will let you know how I make out. Thanks
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
54' chevy 4 door window channel gavinpierce Interior 3 01-11-2011 07:27 AM
installation of a 63 chevy c10 small rear window??? pat63chevy Body - Exterior 1 12-31-2007 03:50 PM
35 Chevy 3 Window Coupe paulm Body - Exterior 14 05-08-2003 12:37 PM
40 chevy coupe rpvette Body - Exterior 3 01-22-2003 05:02 PM
