Vin# On 1937 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2009, 04:29 PM
Vin# On 1937 Chevy
Where Do You Find The Vin# On A 1937 Chevy 2 Door Sedan? We Have The Title But Cant Find A Tag Anywhere.
Old 05-27-2009, 04:34 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
i know on my 53 chevy 210 vin tag is on the ds on the winshield pill
it might be their
Old 05-27-2009, 04:45 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
We had a 1937 Chevy pickup, and the tag was located in the engine compartment on the firewall on the passenger side. Cole
Old 05-27-2009, 07:32 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
my 53 chevy has a body tag on it
on the ps firewall but the vin tag is
inside the ds windshield pill but on that
37 is the vin on the body tag also
Old 05-27-2009, 10:36 PM
Joe G's Avatar
I just had the same problem on a '37 coupe. There was a body tag on the right cowl side and two holes above it, like there should have been another tag there (presumably the serial number).
The VIN on the title turned out to be the engine serial number which is stamped into the block near the base of the distributor.
Hope this helps.
Joe G.
Old 05-27-2009, 11:10 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
hey on my 53 chevy 210 the vin is on a tag
on the ds windshield pill now i do have the
body tag on the right side of the firewall
and the block has a set of numbers
what is so diff about a 37
and to the guy that started this have you called
www.obschevy.com they have helped me out a lot
they might can help you also
Old 05-28-2009, 06:51 AM
serial number
on my 1936 chevy 2 dr. sedan the serial number is located on the passanger side floorboard next to the battery box. i have a 34 and 32 and that where they are at to. i tried to put up a picture but it would not let me. jonathan
Old 05-28-2009, 11:29 AM
your title should tell you the VIN. But what the others are showing you really isn't the VIN. They didn't use VIN's back then. A lot of times the number came off of the engine so you might check that number against your title. They did match up engines and bodies but in the midwest it was common to replace truck cabs that were full of rust.
Barry
vin number on '40 Chevy 40 Rat Rod Hotrodding Basics 5 05-02-2009 10:02 PM
1937 chevy pickup bo Suspension - Brakes - Steering 3 09-14-2006 07:08 PM
VIN stamped on Chevy frame or urban legend? TT66' Hotrodding Basics 7 05-23-2006 11:56 PM
Help regarding VIN - 1940 Chevy Coupe oleeasyrider Body - Exterior 4 03-28-2006 07:49 AM
