vin # and body tags for 50's chevy cars - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 06:54 PM
i just bought a 52? 51? chevy 2 door car the body tag under the hood on the fire wall reads "stile #51-1027 body # 6012 trim # 201 paint 4??(maybe 63)top acc body by fisher" where would the vin # tag be if any ? the title says 52 chevy 2 door vin # 9jkk96### any help? did i get a car with a bad title ? thanks kavin
Old 10-06-2006, 07:25 PM
Wiki Edits: 31
your body numbers do not corrispond with the books. your style no is a '51 number, also the JK in the vin signifies it as a '51 Deluxe Fleetline or Styline. the Vin plate is in the drivers door jamb, front near the top, it's where the door starts to angle back. if you see 2 holes and no tag, get a refund, if it's there and corrisponds with your title Vin, it's a '52 to the gov't. An easy way to tell a '51 from a '52 is a '52 has grille teeth, a '51 has a smooth middle grille bar.
Old 10-06-2006, 07:35 PM
thank you for the info. the tag is there it reads "9jkk96472" it matches the title. the grill is a solid center bar. no teeth. thanks kavin
Old 10-07-2006, 05:21 PM
Wiki Edits: 31
do 1 more check, and check the tail lights and parking lights for the year ( will say GUIDE then the last 2 digits of the year, 51, 52, ect... ). but it looks like you got a '51, titled as a '52, just means it had a lost title at 1 point, and sombody put down the wrong year. My '51 Fleetline is titled as a '50, makes no matter
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
vin location on 1939 chevy master delux jssncaz Introduce Yourself 4 10-24-2006 09:48 AM
decoding vin and cowl tags help todds 67ss Body - Exterior 4 04-19-2006 10:01 AM
gto vin tags on tempest bodies bullheimer General Rodding Tech 6 10-01-2004 07:46 PM
