VIN number location on 1935 Ford Roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2007, 08:23 PM
I have recentely inherited a 1935 Ford Roadster from my grandfather. He owned the car since 1940, I have the original bill of sale and many of the registration cards - 1953 - 1980. What I do not have is the pink slip. Appearantly it was stolen from his house with some other valuables about 10 years ago. I have been trying to get a new pink slip, but the DMV and I have not been able to find the numbers shown as the VIN on the registration anywhere on the vehicle. Does anyone know where those nubers could be? Did engine numbers get used for VIN numbers? Thanks in advance for any help.
Old 06-03-2007, 08:29 PM
302 Z28's Avatar
Early 30's model Fords had the VIN number on the top frame rail drivers side right in front of the firewall and also the right rear top frame rail over the tire I think.
Here is what I found on the web
Other: From 1932 through 1948 vehicles, Ford Motor Company stamped the serial number into the top of the driver's side frame rail in three locations. This same number was also stamped into the top of the transmission-to-engine housing portion of the transmission. This location was visible when the floorboard and transmission cover plate were removed (click here for a picture example). Of the frame-stamped serial numbers, only the forward-most stamping was visible when looking down into the engine compartment (located between the front crossmember and the dash (firewall). The two other frame locations are visible only when the body is removed from the frame. The serial numbers were metal stamped with numbers/letters approximately 1/4" in height.
More information here
Best of luck getting it registered, California can be a real pain.
Vince
Old 06-03-2007, 08:48 PM
bluestang67's Avatar
Last journal entry: rear end detail
On my 31 i had to pull body to see Vin # on the frame it was right under left front cowl section. I received a title but untill i seen numbers match i was a bit worried. States are changing titleing laws so even with a lost title you could build it and retitle it as a 32.
Old 06-03-2007, 09:27 PM
WELCOME to Hotrodders.com
As a fellow Ford roadster owner and a Moderator, I want to be one of the first to WELCOME YOU.
I never owned a 35 Ford ( but I like them ) but what Vince said is the straight info. Here's a photo of the number on the frame of my 32 Ford. It is just at the firewall. I taped it up ... after the first coat of paint ... I did not want the number to disappear in with the paint.
Also ... the numbers were hand stamped and will not be in a perfect line
Old 06-06-2007, 11:38 PM
Thanks for all of the help!
Before I got the responses from you guys, I contacted the Nethercutt museum in Sylmar, Ca. They agreed with what you are saying - the number should be on the top of the frame, on the left front. After some substatial cleaning, I found it. I am going back to the DMV tomorrow. Thanks for the help.
Old 08-18-2010, 02:43 PM
Im sorry I dont see where they are, is it where the grey strip is next to the little hole?
Old 08-18-2010, 04:22 PM
Yes ...
The little strip is where the paint was not applied heavily
This is on a original 1932 Ford frame ...
After 60 or more years ... paint, rust and sometimes abuse make the numbers very difficult to see. I left mine visible ... because in my state ... the DMV will not issue a title for a vehicle that old unless they see the number on the frame.
I just went thru this same thing with my new project.
They would not issue a title without seeing the truck and the VIN number ... even when I had a valid ownership transfer from the Canadian owner and the import certified papers from the United States Government ... where I bought it into the US
It is a 1949 Mercury M-47 1/2 ton pickup ( available only in Canada ) .
Very similar to the Ford F1- pickup.
Old 08-18-2010, 05:59 PM
Cool thanks!!! Nice looking project!!! Since I might have someones attention one more question Do you happen to know if it in the same place on a 46' Ford sedan 2d? Again thanks sooo much!!!!
Yes ...
Old 08-18-2010, 10:19 PM
I have never owned a Early V8 Ford car made after 1940 ... but the VIN number sequence for a 1946 Ford ... is
100 HP models 99A-650,280 to 99A-1,412,709
90 HP models 1GA-227,524 to 1GA- 326,417
From a google search ... the numbers should be on the frame in a similar place on a 1946 Ford ... but as I said ... I have NO ACTUAL knowledge or experience with the 1946 Fords.
40 Ford Roadster Pickup in Australia trees Hotrodders' Lounge 20 02-10-2007 05:47 AM
VIN number decoded cruzinal Engine 10 01-20-2007 04:32 PM
1971 Fastback Mustang VIN Number onebadmerc Hotrodding Basics 17 01-07-2007 07:29 PM
serial number location 46-48 ford? bob myers Hotrodding Basics 8 01-06-2007 03:11 PM
vin location 37 ford truck bigalparts Hotrodding Basics 4 11-03-2006 05:24 AM
