vin numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 01:43 PM
New Member
Post vin numbers
Just purchased a 1980 GMC van. Needs new support bearing for drive shaft and I can't find anything to help me. It has a 350 motor and a 400 trans can anyone help with vin code its TGL25A4504670. Thanks. <img src="confused.gif" border="0">
Old 01-14-2003, 11:39 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
You mean your local parts supplier cannot get one. I don't believe the VIN isn't going to do you any good.
Kevin
Old 01-14-2003, 11:41 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post
Tell the parts store you are looking for a 'carrier bearing' they should be able to help you out.
Later,
WEIMER
Old 01-14-2003, 11:50 PM
New Member
Post
Parts store needs to know if its a 1/2 ton 3/4 ton ect. To get the right part. Thanks
Old 01-14-2003, 11:52 PM
Weimer's Avatar
Post
Is it a G10, G20,...?
G10 = 1/2 ton
G20 = 3/4 ton
G30 = 1 ton
Have you tried the parts store yet? They should be able to figue out what you have...
Later,
WEIMER
Old 01-16-2003, 10:21 AM
New Member
Post
that there is where the problem lies someone did a home paint job and took all the lables off so there is no info to tell what series it is lol
Old 01-16-2003, 01:08 PM
Post
Take out the old bearing assembly and match it up at the parts store. There should only be 2 choices. Even if you knew the truck designation that would not guarantee it uses the indicated bearing assembly from a catalog. GM kinda didn't follow the rules on these bearings and driveshaft deals. 25+ years in the parts business have taught me that!
