VIN question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 09:15 AM
VIN question
Can anyone tell me where to locate the engine #'s on a Ford 351. I'm trying to determin if this is a small or big block, or, if it's a windser, cleveland or modified. the only #'s I can see are by the water pump which are 3C 8G. It's in a 36 Ford so I'm not sure of the year either.
Old 01-22-2006, 11:56 AM
327amc's Avatar
Owner of a broken cart
check directly below the ignition coils stock location. thats where mine is.
Old 01-22-2006, 08:50 PM
milner's Avatar
on a ford the numbers are on the side of the block under the exhaust manifold. also if it has a separate timing cover case, it is not a Cleveland or a modified. if it has a timing cover that is part of the block, and has square castings on top of the timing cover, it's a modified. keep us posted.
VIN question ditneal Introduce Yourself 3 01-22-2006 09:07 PM
Question on VIN numbers? 68 GTS Dart shaggy Hotrodders' Lounge 3 03-06-2005 01:03 PM
Help! Important VIN question AK47 Hotrodding Basics 5 12-08-2004 07:48 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
need more help to id vin / deck question el Engine 7 08-12-2003 11:43 PM
