vin question
I need help to locate the engine #'s on a Ford 351. it's in a 36 Ford so I'm not sure of the year either. I'm trying to determine if this is a small or big block and if it's a cleveland, windser, or modified. the only #'s I can locate are next to the water pump and they are 3C 8G.
Look under the ignition coil for an ID tag.
351W had: 6-bolt valve covers Coolant bypass hose from thermostat housing to WP Thermostat housing mounts horizontally Fuel pump bolts aligned horizontally 351C had: 8-bolt valve covers No bypass hose on thermostat housing Thermostat housing mounted vertically Fuel pump bolts aligned vertically The terms "big block" and "small block" don't really apply here either. Based on the transmission bolt pattern, 351C/W are both "small blocks" You may even have a 351M in there. Their characteristics are similar to those described above for the 351C, but they have the "big-block" transmission bolt pattern (same as 400/429/460) This has been discussed here (hotrodders.com) many times ... search thru the engine section, and I'm sure you find lots of good information. |
| VIN question | ditneal | Introduce Yourself | 3 | 01-22-2006 09:07 PM |
| VIN question | ditneal | Hotrodding Basics | 2 | 01-22-2006 08:50 PM |
| Question on VIN numbers? 68 GTS Dart | shaggy | Hotrodders' Lounge | 3 | 03-06-2005 01:03 PM |
| Help! Important VIN question | AK47 | Hotrodding Basics | 5 | 12-08-2004 07:48 PM |
| need more help to id vin / deck question | el | Engine | 7 | 08-12-2003 11:43 PM |
