VIN # and rear end gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2005, 03:42 AM
first i would like to thank the guys who answered my "trans knock" thread, turned out to be the converter. So im upgrading my trans anyway to 200r4 trans, but the company who's building said they need the rear end gear ratio. was wondering if anyone could tell me what it was off the vin#.
79' olds cutlass
tag on the dash reads
*3R47H9M511910
tag on the fire wall reads like this
79 03A 3AR4 459417
19V 19L 19U L
B51 D35
A0 515
if that dosent help, can anyone tell me how i can figure it out without taking off the rear end cover.
Old 11-24-2005, 09:17 PM
If it has the original gears in the housing, you can use the alpha-numeric code stamped on the right-hand axle tube. It's usually stamped (sometimes lightly) in the upper front part of the tube, just a few inches outboard of where it meets the center housing. It's usually covered with dirt & grime, so bring something to scrape with when you go under.
Here's some code info: http://tech.oldsgmail.com/axle_useage.html
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
VIN Probs for the Trans and Axle mike Clothier Transmission - Rearend 2 09-10-2003 09:44 AM
Decdoing a vin number for a 1978 Camaro redcamaro4spd Engine 2 08-06-2003 09:58 PM
rear end ratio kors86chevy Transmission - Rearend 10 02-02-2003 03:50 PM
