Vintage Air Gen II problem? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-02-2011, 03:53 AM
EOD Guy's Avatar
If the mounting bolt is bolted thru the body/firewall.... wouldn't that be a good ground? (assuming the body is grounded)
  #17 (permalink)
Old 08-02-2011, 05:37 AM
Irelands child's Avatar
Most try to not add holes to the firewall for appearance sake. It's usually painted, or, in many cases, a street rod is fiberglass bodied. The mounting arrangement for Vintage Air is a bracket but is mounted on the pass. side.
With a 'glass bodied car, the car builder usually has some sort of ground system that's generally directly connected to the main ground for the battery, usually the engine.
  #18 (permalink)
Old 08-02-2011, 05:30 PM
EOD Guy's Avatar
I see your point..... I realize fiberglassed bodies need a ground, point was "IF" the body/firewall was grounded, why wouldn't a mounting bolt make a good ground? I could have been clearer..... and stated firewall ground system/strap etc....
  #19 (permalink)
Old 08-02-2011, 07:28 PM
Joe G's Avatar
Registered user
The mounting bolt I was talking about is the bolt on the back of the dash control panel, not the ones that holds the main unit to the firewall. Most of the Vintage Air control panels do not have through-bolts that attach them to the dash. They have clips that press against the back of the dash and clamp the control panel in place as you tighten the screws. Usually, when a car has been repainted or restored, there is far too much paint in the area where the clips clamp against the dash to get much of a ground at all.
IMO, a thru-bolt can work but is not an ideal ground. Threads offer more surface contact area than the tip of a lockwasher can, so I try to make all my grounds either sheet metal screws, or on heavier metal, machine screws into tapped holes.
That's what my auto-wiring mentor drilled into my head, anyway. Opinions may vary.....
  #20 (permalink)
Old 08-03-2011, 05:16 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Vince,
Can't help you with your valve problem, but the thread prompted me to check mine and sure enough, the valve was partialy open. But, it was because the valve won't fully close with the fan in the off position.
Once I turned the fan on, the valve closed the rest of the way so now I know to keep an eye on it.
  #21 (permalink)
Old 08-07-2011, 08:49 AM
ogre's Avatar
the 'Duracell Project'
Originally Posted by Joe G
i like my VA system, but their connections leave a lot to be desired. the control panel connection should be a plug, not 15 single spade connectors. i have more problems with a single spade connector working loose than anything else. usually while i'm working under the dash.
it would be a big improvement if VA put a pigtail and a single plug on their systems.
Vintage ************* GenGuy Introduce Yourself 2 06-19-2011 06:26 PM
Vintage Air gen II ogre Hotrodders' Lounge 3 10-25-2010 12:06 PM
Vintage Air problem 302 Z28 Electrical 2 08-02-2010 08:20 PM
Vintage Air problem 302 Z28 Electrical 14 03-03-2009 07:09 PM
? for Vintage Kevin45 Hotrodders' Lounge 1 10-12-2002 04:13 AM
