Here are some of the problems I have seen with those servo water valves that could cause a condition like you are describing:
1. They are directional. If installed backwards they do not completely close and always let a little hot coolant into the heater core. 2. They don't like straight water instead of antifreeze in the cooling system. The servo valve needs antifreeze for lubrication. 3. Like any electronic device, the servo control module needs a very good ground to work properly. It seems strange that you can move the valve manually because it's a worm gear drive inside the servo. When you push it closed, how far does it move? Did replacing the valve ever fix the problem, even for a short while? Good luck... |
Oh is yours cable operated?OLDROD |
| Problem with air compressor "splatter". | anselmo107 | Body - Exterior | 14 | 02-28-2010 07:04 PM |
| Best price on Vintage Air units? | super_kev | Interior | 12 | 05-31-2005 06:02 AM |
| Bad Air Valve | black66 | Electrical | 8 | 04-12-2005 12:44 PM |
| Orange peel in the clear | Montypierce | Body - Exterior | 13 | 03-06-2005 08:49 PM |
| air shock problem... | Firebird69 | Suspension - Brakes - Steering | 4 | 09-16-2004 12:04 AM |
