Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vintage air question
Old 07-07-2010, 02:43 AM
Joe G's Avatar
Joe G Joe G is offline
Your Gen II Mini system has 3 servos. Two of them are mounted on the AC case and are usually plugged in to the control module harness from the factory. The other servo plug connects to the electronic water control valve, which gets installed on the inbound heater hose.
Hope this helps...
