Vintage air question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 03:03 PM
Hello guys I'm new here and have a question about a gen 2 mini heat cool defrost unit, I restored an old Ihc kb 5 I have it completly installed except wiring I understand how to wire everything except the one plug that is a servo plug the diagram shows nowhere to plug it in and there's no place to hook it up is it supposed to be connected I would apreciate some of you guys help I'm sure y'all have installed many thanks
Old 07-04-2010, 09:22 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
It may not be used on your application.
I have a Gen IV for my 66 Elky
Have servo motors for Fan, Temp, Blend.
The harness that came with the kit included plugs for 4 servos but I am only using 3.
The plug with the white/blue wire is not used.
Old 07-04-2010, 09:41 PM
I'm not sure, I looked on their site the diagram is just like mine I have a four knob streamline panel, the diagram shows 3 possible servo plugs mine only has one but there is no place for it, at the bottom of the diagram where it shows the plugs it doesn't show any termination of the plugs, the rest of the wires all have a termination point shown just kinda confused as to what to do! Figured I would tap some knowledge online before the holiday is over and could contact vintage!
Old 07-07-2010, 01:43 AM
Joe G's Avatar
Your Gen II Mini system has 3 servos. Two of them are mounted on the AC case and are usually plugged in to the control module harness from the factory. The other servo plug connects to the electronic water control valve, which gets installed on the inbound heater hose.
Hope this helps...
Thermostatic Air Cleaner Question. Again. BinderDriver Engine 5 05-28-2010 09:29 AM
Yet another Air Compressor Piping Question..... deadchane Garage - Tools 2 03-25-2010 08:57 AM
Trouble shooting Vintage Air for the Novice wretched ratchet General Rodding Tech 8 05-07-2008 07:27 AM
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 06:41 PM
Question on air supply setup for painting PurpPplEatr Body - Exterior 25 05-03-2004 04:43 PM
