-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Vintage Air System in 56 Chevy Pickup (http://www.hotrodders.com/forum/vintage-air-system-56-chevy-pickup-219751.html)
Piston1 05-23-2012 11:25 PM
Anyone have pictures of the condensor & dryer installation in their truck? I've got the condensor mounted but the radiator will need monifications to fit back in (aftermarket US radiator, 4 core). Plus the dryer & lines I recieved don't seem to fit according to their instructions.
Thanks,
Ken
ogre 05-24-2012 09:52 PM
i have the same radiator as you do, ordered from brothers, drop shipped from us radiator.
this is how the lines fit from vintage air on my 58
http://i306.photobucket.com/albums/n...intageAir9.jpg
the lower line will not attach to the dryer and the upper line did not go thru the factory hole
i lowered the condenser using other brackets that came with the kit, not the ones for the 55-59 truck
line up the condenser to allow the upper line to go thru the factory hole, by lowering it.
then i made a hose with the right ends on it to hook into the dryer
the dryer is right on the other side of the hose 90* and mounted to the radiator support
i think they mix parts in the kit, if your set up looks like mine
http://i306.photobucket.com/albums/n...K/truck036.jpg
http://i306.photobucket.com/albums/n...r/IMG_1301.jpg
Piston1 05-31-2012 10:33 PM
Thanks for the reply & pictures ogre. Mine is slightly different as it is a 56. The dryer bracket mounts on the outside & I'm guessing it sticks through one of the 1-3/4" holes I need to cut in the support. The upper line seems to work but I can't seem to figure out the lower line. It sticks out way too far & it looks like the dryer mounts on the outside of the support. There's no way the grill will go on like that.
Once I figure out how to post pictures I will.
http://www2.snapfish.com/snapfish/sl...NAME=snapfish/
Ken
Piston1 05-31-2012 11:05 PM
2 Attachment(s)
I think I got it...
