Vintage Air System in 56 Chevy Pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2012, 10:25 PM
Anyone have pictures of the condensor & dryer installation in their truck? I've got the condensor mounted but the radiator will need monifications to fit back in (aftermarket US radiator, 4 core). Plus the dryer & lines I recieved don't seem to fit according to their instructions.
Thanks,
Ken
Old 05-24-2012, 08:52 PM
ogre's Avatar
the 'Duracell Project'
i have the same radiator as you do, ordered from brothers, drop shipped from us radiator.
this is how the lines fit from vintage air on my 58
the lower line will not attach to the dryer and the upper line did not go thru the factory hole
i lowered the condenser using other brackets that came with the kit, not the ones for the 55-59 truck
line up the condenser to allow the upper line to go thru the factory hole, by lowering it.
then i made a hose with the right ends on it to hook into the dryer
the dryer is right on the other side of the hose 90* and mounted to the radiator support
i think they mix parts in the kit, if your set up looks like mine
Old 05-31-2012, 09:33 PM
Thanks for the reply & pictures ogre. Mine is slightly different as it is a 56. The dryer bracket mounts on the outside & I'm guessing it sticks through one of the 1-3/4" holes I need to cut in the support. The upper line seems to work but I can't seem to figure out the lower line. It sticks out way too far & it looks like the dryer mounts on the outside of the support. There's no way the grill will go on like that.
Once I figure out how to post pictures I will.
Ken
Old 05-31-2012, 10:05 PM
I think I got it...
ID:	65747   Click image for larger version
Air conditioning---Vintage Air with a R-4 compressor Bryan59EC General Rodding Tech 1 01-02-2010 03:34 PM
62 chevy pickup rear end carrier into Bel Air Tymer Transmission - Rearend 1 07-30-2008 09:14 PM
Ford Mass Air System on a Chevy V8 RippinRon Engine 0 03-20-2006 07:44 AM
Vintage auto alarm system????? 421Bonneville Electrical 2 09-17-2004 05:53 PM
vintage air in 57 chevy brad11957 Engine 0 11-18-2003 05:09 PM
