Vintage headlite reflector painting or plating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2014, 10:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Headlite reflectors on my 1948 Simca are real dull, lost plating, lost shine.
This car will Not be a street driver, it will be a drag car in a gasser style.. , I just want the reflectors to look decent through the glass lens.
Paint them with a spray can? I dont want to bust the budget on something that only needs to look decent through the lens
Photos of one reflector, I used a SOS pad on, I also tried some Wenol polishing liquid on same lens too.
You can see what looks like copper showing through on this , so I guess lens was chromed.
The top part of this lens is untouched by me. On the left was cleaned with SOS pad.... on right side I used the blue tube of Wenol
Old 06-17-2014, 12:41 AM
327NUT's Avatar
I tried a few different spray can methods but they really just come out as a shiny silver finish.....which may work for you. If you go to youtube and type in Chrome paint finishing you'll see quite a few different application techniques. Jay Leno has a guy on there that has a 3 step type process that may be the thing you want, it really makes the parts look like chrome or as close as you're going to get.
Old 06-17-2014, 11:41 AM
silvering or powdercoating chrome will both work. The chrome powdercoat does NOT like to be handled. They normally put a clear over it, which changed it from chrome look to more like polished aluminum. I bet if the headlights are sealed, the chrome-look wouldn't need a clear anyway. talk to your local powdercoater. be mindful of the film build since you have to reassemble it
Old 06-17-2014, 01:55 PM
ericnova72's Avatar
More for Less Racer
I would say the bright reflective silver powdercoat method is going to give you the best result short of re-chroming, it comes very close to buffed stainless or aluminum in appearance.
Old 06-17-2014, 05:19 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
There's a older fella I know who says painting the surface white works better than anything else.... says that's what he has always done. FWIW
Old 06-18-2014, 04:29 AM
Last journal entry: 50 Ply wagon
I repainted some older tail light housing in the same condition. I sprayed them a bright silver and I am using these on the street. They are very bright and there are no problems seeing them.
You are using this on a drag car.................just spray them either bright silver or white..................do not powder coat something when you can finish it for the price of a can of paint.
Old 06-18-2014, 02:54 PM
ericnova72's Avatar
More for Less Racer
I've used the "Fake" chrome spray paint in tail light housings and front driving/turn signal housings, and it seems to work there, and have seen white used there also, white seems to make a softer, more diffused glow.
I don't know if white is going to look good in a head light application compared to something at least trying to be reflective(fake chrome or bright silver)
Old 06-18-2014, 04:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try this:
Premium Metallic - | Krylon
This stuff looks OK and the bling on the engine will distract from the headlites...
Sam
Old 06-19-2014, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks for suggestions. Never thought of white paint.
I will phart with the reflectors this weekend, see what I can goof up.
Old 06-19-2014, 08:13 PM
Agreed. Nate is a wealth of knowledge, his comments can be found on post 183, here: Skeeter's 50. Questions and Build - Page 13 - Classic Parts Talk
Originally Posted by vwnate1 View Post
.... Those big stop lamps light up best when you remove the internal reflector and paint it gloss white ~ this causes the bulb's light to fully illuminate the glass lens.
Old 06-23-2014, 10:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I had some gloss white paint here. Tried that first. Did not look quite right behind the clear headlite lens.. Behind a red lens on tail lite, I bet that would work very nice
bought some Valspar metallic paint in silver. Looks good.
Thanks for the help
Old 06-30-2014, 10:29 AM
1971BB427's Avatar
Too late now, but I was going to recommend polishing them with Mothers paste polish. The reflectors on my old Austin gasser looked like yours also. I used Mothers paste and they came out really looking great! I could still see some thinning areas, but since the reflector was so shiny they were impossible to see through the glass when it was assembled.
"Basics of Basics" Taillamp reflector retrofitting MARTINSR General Rodding Tech 36 02-04-2016 09:34 PM
Weight Loss- headlite actuator removal aisr General Rodding Tech 0 10-08-2012 06:36 PM
You need vintage tools for working on vintage cars. :) MARTINSR Hotrodders' Lounge 20 11-16-2011 09:58 AM
1939 Dodge glass headlite lense TooMany2count Body - Exterior 0 05-23-2004 02:08 PM
Tri bar headlite Nigel Electrical 2 11-14-2002 03:29 PM
