Vintage Sun Tach Hookup model ST-602 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2010, 08:17 PM
Just purchased a '60's Sun Tach model SR-602 to use on my '27 Roadster rat rod, which is running a small block chevy with HEI distributor. It's a four wire hookup Ign. SW, ground, light and trigger. My question is where do I hook up the 'trigger' wire for an HEI? If it's the HEI, where? Any help is appreciated.
When I posted this answers from 2002 & 2003 came up, I'm hoping they will work. My wire colors don't match but the back of the Tach identifies what each wire is.
Old 06-16-2010, 08:24 PM
ericnova72's Avatar
More for Less Racer
Trigger wire gets hooked to the post marked TACH, in thr cap right next to the 12v+ feed wire to the HEI.
Hope this isn't one of the Sun tachs old enough that they had a seperate trigger box, you will be out of luck if it is.
how to wire a sun super tach teds 46 Electrical 4 11-06-2011 01:56 AM
Sun Super Tach Re-pop PatM Electrical 4 03-03-2010 04:45 PM
Sun Tach. Wiring Help 383vette Electrical 4 10-02-2004 02:00 PM
Vintage Sun Dwell Tach jackt0402 Introduce Yourself 2 08-18-2004 03:37 PM
sun tach wiring bullheimer Electrical 16 01-12-2004 04:09 PM
