vinyl interior - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2004, 05:09 PM
bct bct is offline
vinyl interior
I have a 32 Ford 5 window coupe. I want to install a black vinyl interior. I have the door panels and headliner figured out. I'm having a problem designing a panel that will go from the back side of each door and cover the area around the rear quarter windows and the back window. Its quite a bend to use any thing like thin plywood. Any info or advice will be appreciated.
Old 02-01-2004, 06:48 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Check out sheets of PVC (plastic) ... you can heat them and form them, too!
Alan
54 Chevy Pickup
Old 02-01-2004, 07:14 PM
bct bct is offline
Thanks for the info Horvath. I would like to put some foam backing between the PCV panel and the vinyl to give it a little depth. Do you know what the best glue to use would be?
Old 02-02-2004, 07:01 AM
kristkustoms's Avatar
First name...............Shawn
1/4" Landau Top Foam/Closed Cell Foam
Read this thread for info on glue:
http://www.hotrodders.com/t33115.html
Old 02-02-2004, 03:17 PM
Dave E Shank's Avatar
HEY BCT: I was finishing the inside of my trunk lid with carpet. It had a quick bend and I could not find a material that was that flexible. I finally found Formica sheets at Lowes, Home Depot in the kitchen Cabinet Dept. I found a piece of thin Masonite in the paneling department that was used as a shipping cover on a bundle of panelling in the broken panel bin for $ 5.00 and it worked okay. There is also thin plastic sheeting around the panel department, just take your time and look around.....GOOD LUCK...DAVE
