Has anyone tried the vinyl and interior plastic trim paints on the market? I have a set of white bucket seats that I want to change to dark green. They are vinyl with a cloth center strip. The backings are plastic. Would I need different paints for each surface? How well does it adhere and last?
Thanks in advance.
Mar-Hyde (div of Bondo) makes a very good vinyl dye for the plastic and vinyl parts, the cloth will need a dye for nylon or dacron. The vinyl dye lasts quite long if the seat is prepped correctly, but will eventually wear off the piping and edges. Check previous posts, you will find other brands and ideas.
Valspar is the parent company of house of colors paint,Krylon and a few others. Its good to use a primer on plastic parts first.
Heres the interior paint and dyes site.
Just for possible paint compatibility issues, Valspar does not own Krylon. Sherwin Williams owns both Krylon and Dupli-Color, so I TRY to stay within brands. However, I have found the Plasti-Cote Plastic Filler/Sandable primer to be an excellent product under anything.
This is the best stuff I've ever seen for dying Vinyl and/or leather. ColorBond It has more colors than just about anyone else and just like the other brands mentioned it is very durable.
Centerline
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
