Vinyl Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2003, 10:34 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Vinyl Question
I'm covering my new side trunk panels with black vinyl, is there any tricks for getting the vinyl to wrap around a complex curve (i.e. a backward 3 at a 45 degree angle). Or would it be better to put a beading around the edges?
Regards
Mark
Old 09-30-2003, 11:08 AM
malc's Avatar
Living At The Speed Of Life
Pie cuts on the strip you fold over the back, helps stop the material from wrinkling.Do them about an inch apart.
Old 09-30-2003, 08:19 PM
BOBCRMAN@aol.com's Avatar
Also if you use an electric hair dryer to heat the material as you form it it will form better, get the type of vinyl thay will stretch, such as elastic back, some twill back or heavy materials won't do well.
