Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vinyl Top Glue
Thread: Vinyl Top Glue
Old 04-04-2012, 01:26 AM
nine4gmc's Avatar
nine4gmc nine4gmc is offline
sorry, I must not have been clear. Never use aerosol glue on any part that will be in direct sunlight, or high heat areas, it will FAIL. it may look good when you first do it and it stays inside, but after a few days/weeks in the weather, it will fail.
I have only used aerosol glue to tack vinyl to pad before sewing. ANY other gluing and I use the compressor and spray gun with either 3M Contact Cement or the Landau Top & Trim Adhesive in gallons/5 gallons.
I do not reccomend aerosol for any job that won't be sewn, stapled or some how secured around the edges other than glue.
