Vinyl top removal, 69' Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2008, 07:38 AM
Hey guys I am new to the restoration process and was wondering if anyone could help me out. I have a 69' chevelle malibu, I am looking to transform it to a hard top from the black vinyl top on it now... I hear these are a real pain in the you know what to get off, any suggestions would be greatly appreciated
Old 11-11-2008, 07:41 AM
poncho62's Avatar
Wiki Edits: 5
Not hard to get off, but a pain to clean up the mess they cause.......Be ready for glue.....and rust. Hopefully, it didn't rust too bad under there, but I have seen very few that didn't.
Old 11-11-2008, 10:46 AM
what is the best way to remove the adhesive?
Old 11-11-2008, 11:06 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
After trying most chemical ways,which usually don't work,use a heat gun on low with a putty knife for the worst of it.Then finish up with something like Acetone or such.
You'll likely have rusted out back glass corners,the top/sail panel joint and possiably along the bottom of the sail panel.
You'll have some trim holes to fill,trim stubs to cut off and the top/sail joint to fill. You'll need different quarter glass trim if you plan on putting trim back on as well.
The 69 I did already had the vinyl gone when I got it but nothing else was done.I got pics of all of it so if you need something specific,let me know.
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 07:15 AM
Repair/replace Vinyl top? Jehannum Body - Exterior 5 08-22-2003 07:45 PM
best paint/ prep to put under a vinyl top novajohnb Body - Exterior 1 09-05-2002 07:16 PM
vinyl top on a cadillac? 1970CDV Body - Exterior 2 04-22-2002 11:26 AM
