You have to make sure all rust has been killed or removed first. This can be a daunting challenge. Once that is done you need to follow with a high quality epoxy sealer/primer applied to a properly prepped surface. Southern Polyurethane has a very good product for this. After the epoxy is applied the vinyl top can be installed.
Vince |
Vince laid it down for you bro... Lots of sanding and go with the spi epoxy once it is all perfect.. I would make sure to use 2 good wet coats and let it set overnight or for a day before you glue down the new top
Matthew |
Vince |
| vinyl tops | erythnul | Body - Exterior | 2 | 05-28-2005 05:59 AM |
| vinyl top question | frydz1985 | Body - Exterior | 3 | 10-21-2004 02:27 PM |
| Repair/replace Vinyl top? | Jehannum | Body - Exterior | 5 | 08-22-2003 07:45 PM |
| best paint/ prep to put under a vinyl top | novajohnb | Body - Exterior | 1 | 09-05-2002 07:16 PM |
