vinyl tops - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 04:10 PM
71montebbc's Avatar
Wink vinyl tops
Is it difficult to change a vinyl top? Or is it better to stay away from? I dont know how long they last. Iwill say they look nice when there new. Any advise or knowledge on this would be greatly aprieciated.
Old 02-04-2003, 07:02 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Do you mean a convertable top or a vanity vinyl top on a hardtop?
HK
Old 02-04-2003, 07:30 PM
kiaserknife's Avatar
Post
it is a pain in the arse to do if you dont do it on a regular basis....let the pros handle it.
Old 02-04-2003, 07:39 PM
banned
Post
Vynal over top of metal severly increases the rate of corrosion... I wouldn't reccomend it but if you like the look go for it.
Also if it is good vynal it will probably outlast the paint under it.
[ February 04, 2003: Message edited by: stonedchihuahua ]</p>
Old 02-05-2003, 04:00 AM
71montebbc's Avatar
Red face
Its vinyl over a hardtop. Just as i figured; This is the first time messing with them. So what is the best way to remove it? That looks to be a job also.
Old 02-05-2003, 05:04 AM
Post
If your top is cracked or torn it is forming pockets for rust and corrosion as we read this note. The worst tops for rotten tops are the padded ones. Just cut the material with a boxcutter around the perimeter of the roof, and peel it like a skinned cat. Be prepared to be exposed to gross rust chips and possible holing especially at the lower rear quarters of the roof pillar at the top of the rear fenders. The top should be sanded, rust damage repaired, and then primed and finish painted (color is not important if you're replacing the vinyl, just use what you have in a good quality paint).
Old 02-05-2003, 03:51 PM
71montebbc's Avatar
Wink
So far its got a lot of dry cracks and its faded; its the original. I will get it off. hopfully its not all rusted. It has chrome molding around it; Do i have to pull the headliner plus the rear panels? Or do they snap out?
