Viscosity questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2012, 12:45 PM
ecs ecs is offline
Viscosity questions
First off, I've seen about a hundred threads of guys rolling rustoleum on their cars. No, this isn't what my thread is about. I'm using a sprayer, but still, the rustoleum is not going on the car. I decided to break out my electric "HVLP" (should be called LVLP) sprayer to see if it did anything other than spray bullets since I never used it before. I picked up a quart of black gloss rustoleum and a quart of acetone to thin it out. I have scrap metal and a trashed front bumper from a 1995 Cirrus to practice on. I just wanted to know if the sprayer had what it takes to atomize the paint. After an hour or two of fiddling around with the thinners (20% was too thick, even 30% was too thick, 50:50 acetone to paint did the best) and the flow setting on the gun, and I think I started to make progress. I got the paint to lay on with minimal orange peel and no runs.
I'm starting to think that this gun won't be able to lay down a decent finish unless the paint is thinned out enough. Which leads me to this question: Do you think that automative urethane (either SS or 2k) paint is less viscious than the rustoleum enamel paint? If so, I think I might try to spray the auto paint out of my "turbine" sprayer. I feel like the orange peel effect is coming from the reducers (acetone in my recent case) evaporating from the surface and leaving pits, hence the orange peel. It's just a theory, as I'm just a beginner in terms of painting; but I've done quite a bit of reading and research.
Don't worry, the scrap pieces will take the punishment of testing any kind of paint before it goes on my car.
Also, a sidenote. Even after leaving a piece of exhaust pipe covered in the black rustoleum paint out in the sun with temperatures ranging from 70-80 degrees for a week, the paint still hasn't cured. I'm able to make an indentation in the paint without much pressure. That's one of the big reasons why I won't and refuse to use enamel on my car. It takes far too long to cure, and for a daily driver, the stone chips/salt rocks will DESTROY the paint before it even gets a chance to cure. It was a great test though to see how the sprayer laid down the paint.
And drumroll... here's the sprayer I used.
I know, many of you are cringing at it, but being honest, it didn't do a bad job as far as I can tell and there was a VERY minimal amount of overspray. Then again I've never sprayed with a compressor+hvlp setup so comparing the two isn't my place. I just tried to get it to work by adjusting how thin the material was (since it has no air adjustment setting) and adjusting the flow output. It takes time, but then again I don't know any spray system that you can just pick up and go. All of them require some fine tuning IMO.
Additionally, the air output NEVER got any warmer. It stayed almost exactly the same as the ambient air, if not cooler somehow. I know a lot of guys are saying that turbine systems warm the air. Mine didn't. Might be because I don't have the huge box 4 stage turbines that they do.
I didn't want to post pictures since the majority of the ones I've seen with rustoleum paint jobs look nice through a lens, but at the perfect angle or in person, you can see MASSIVE blemishes. I didn't encounter any significant blemishes other than orange peel but I doubt I'll be able to get the orange peel to show the same in the photos as they are in person. If anyone wants to see them, just ask.
Old 05-15-2012, 01:23 PM
I have sprayed cars with rustoleum with old suction feed guns...never ran any through an hvlp, all mud bog and off-road type stuff. It has been a real long time, but I believe I cut it 75/25 with acetone. I have gotten very good results for the product used, dries fast, and fairly durable for the application. Any paint will get damaged on the trails and spraying cheap rustoleum makes for easy touchups. I shot my bog trucks with real auto paint, but not all make that choice and I can understand the reason.
I am not really sure what your question is other than what viscosity to spray at. Just thin it down until it sprays good is about all I can say; that is what I did. I doubt you will get much help from this forum on this topic. With a bit of creativity you can get the paint to lay real nice. Painting competitors vehicles with rustoleum is what got my interested in paint and body work. I no longer shoot rustoleum or any real "hack" work (I will only use urethane), but by all means go for it. Real body men may laugh, but living your life for others doesn't make it very meaningful.
Old 05-15-2012, 01:37 PM
ecs ecs is offline
Sorry, seemed to ramble on in the original post. I was trying to test out my turbine sprayer to see if it could atomize the paint well. When it did it successfully, I decided that I had too much orange peel from overreduction (or maybe underreduction...but I wouldn't want to go past the 50:50 mark). The question was: how viscious (thick) is auto paint (BC/CC or SS) compared to the viscosity of Rustoleum enamel?
I was wondering if anyone has ran both through a ford or zahn cup or if anyone remembered how much they had to reduce the rustoleum to get it to spray and how much they had to reduce mfg x's auto paint.
I'm definitely not spraying my car with rustoleum, but trying to get an idea of how well auto paint will spray out of the gun based on the different viscosities. I might just end up biting the bullet and dishing out some cash for a single stage can then going for it. If it laid down the rustoleum on the scrap metal decently, it has to lay down auto paint better if not as good..ya?
Old 05-15-2012, 10:12 PM
milo's Avatar
point on positive
hard to put in words but I could show you..
http://youtu.be/L8Jws5FauSk
Multi viscosity oil question yragat Hotrodding Basics 2 05-10-2012 10:50 AM
Which oil viscosity? Madmax305 Hotrodding Basics 4 02-18-2011 06:47 PM
Short guide on tips and viscosity. cjperotti Body - Exterior 15 06-02-2009 06:17 PM
Paint Viscosity Follow Up x711 Body - Exterior 14 12-01-2005 11:14 PM
Oil Viscosity And Bearing Clearance Relationships HJCHEVY400 Engine 9 04-16-2004 01:29 AM
